| Use? |
Module |
Quantity |
RepRap v1.0 "Darwin"
The entire RepRap machine, ready to print. |
Cartesian Robot v1.0
The 3D positioning system, ready to position. |
Thermoplast Extruder v1.0
The thermoplastic extruder, ready to extrude. |
Thermoplast Extruder v1.1
Support Extruder v1.0
The support extruder, ready to extrude support material. |
Universal Controller v1.2
The universal controller, ready to be specialized. |
Stepper Controller v1.2
The stepper controller, ready to control an axis. |
Extruder Controller v1.2
The extruder controller, ready to control an extruder. |
PowerComms Board v1.2
The power/communications board, ready to provide power and communications. |
PowerComms Board v1.3
The power/communications board, ready to provide power and communications. Now with blinkenlights. |
Opto Endstop v1.0
The opto endstop board, ready to provide endstops. |
Stepper Tester v1.0
The stepper tester, ready to test and blink. |
Extra Parts Kit
Extra parts, in case you dont trust yourself. |
Pulley Molds Kit
Pulley molds, if you want to make your own pulleys. |
Tools Kit
Tools you will need to build a RepRap. |
RepStrap v1.0 "Seedling"
This is an easy to build repstrap machine to get you printing |
Arduino Based Electronics
These are the 2nd generation electronics |
PWM Driver v1.0
This board allows you to drive 3 channels of up to 5A each |
PWM Driver v1.1
DC Motor Driver v1.0
This board allows you to drive 2 small dc motors. |
DC Motor Driver v1.1
This board allows you to drive 2 small dc motors. now with leds! |
Stepper Motor Driver v1.0
This board allows you to control one stepper motor |
Stepper Motor Driver v1.1
This board allows you to control one stepper motor (with LED's now!) |
Temperature Sensor v1.0
this board does temperature monitoring |
Temperature Sensor v1.1
McWire Cartesian Bot v1.2
this is a cartesian positioning system for printing |
Arduino
this is an easy to program microcontroller board based around the atmega168 |
Arduino Breakout v1.0
a breakout board for the arduino for easier wiring - never released |
Arduino Breakout v1.1
a breakout board for the arduino for easier wiring |
Arduino Breakout v1.2
Thermocouple Sensor v1.0
an easy to use, high temperature sensor |
Opto Isolator v1.0
an optical isolator |
Magnetic Rotary Encoder v1.0
a magnetic rotary encoder board |
| Deep Lookup? |
